mbellek
I've been working with more Dymondwood lately, and I also bought a belt sander recently. I use the belt sander off the ends of my work.
I've not had much of a problem with sanding scratches, or marks in my work until I started using Dymondwood, but now I'm finding big scratches from sanding on the lathe, and big grooves on the ends of my work where I finish it off on the belt sander.
I tried to take a picture to post, but I can't seem to get that detailed with the digital camera that I have...
My sanding process usually goes like this:
100 grit
120 grit
280 grit
320 grit
400 grit
then I use this 400 grit that is on a piece of purple foam, but it is much softer than 400 grit paper, I finish up with that usually.
When doing the ends on the belt sander, I just sand it down to what I need, then I use the same papers as above to hand-sand it.
These methods have always worked with other woods.
Any suggestions about what I should do differently? Should I be using a lower speed to sand on the lathe? Should I be not using the 120/100 grit sandpaper? It seems to be because I am going againse the grain of the wood, because I am using straight-cut d-wood...
Ugh![xx(] I love the way Dymondwood looks, but I'm starting to see why so many people hate working with it!!!
100 grit
120 grit
280 grit
320 grit
400 grit
