scratches in my ebony
penbros
omaha, NE, USA.
i turned an ebony pen today and i saw that there were lots of UGLY scratches. i was wondering who knew to resand and get those scratches away or if its possible?
thanks
Daniel
Reno, NV, USA.
It is possible, Ebony as well as all dark woods give me fits when it comes to getting all the sanding marks out.
sand the blanks on the lathe while it is turning, then shut off the lathe and sand with the grain or the length of the barrel until you don't see the marks from sanding while the lathe was running. then move on to your next grit of sandpaper. also wipe the blank clean after each grit as particals left behind can cause new scratches.
good luck
penbros
omaha, NE, USA.
thanks daniel[:)] it really worked. but u were right it is impossible to get all of the scratchesbut looks like a polished black shoe
