avbill
What I like to Learn more about is sandpaper and the quality of sanding I already sand with a low speed â€" Thank you Russ Fairfield. And I sand through all grits
80 100 120 150 180 220 240 280 320 400 500 600 800 1000 1200 1500 2000.
My main objective is to have the wood finish so near to perfect what then I place the finish on the pen it glistens and sparkles.
I just learn through the forum about micro-mesh sandpaper. Reviewing the chart I could have two options:
1.) I could stop at regular sandpaper 400 and continue with micro-mesh 1500, through 12,000.
2.) Or I can continue to sand through 2,000 grit and finish up with 6,000 8,000 and 12,000 grit micro-mesh.
With acrylic, I’m wet sanding from 600 â€"on up While I’m starting at 3600 grit with the micro-mesh
Any comments please! Thank you Bill Daniels
