Sanding segmented suggestions?
Rmartin
Columbus, Ga, USA.
I made a pen today for a friend's sister. She is a fan of Florida football. So I used some blue dyed and stabilized maple with some orange plastic.
The problem I had and have had before when sanding segmented pieces of different hardness is they don't sand evenly. I can feel little ridges. I evened it back out with a light pass of my round nosed scrapper, but then I'm left with needing to sand again.
Have you had this problem? How do you deal with it?
Drstrangefart
Woodstock, Ga. U.S.A.
I use the skew. Make sure it's really sharp and use the touch of a neurosurgeon. Add a couple of coats of thin CA, sand the CA down, then finish as usual. See if that helps any.
hewunch
Albany, GA
If you use a flat tool like a scraper or skew on it's long side or a carbide tool you can skip sanding altogether if you need to.
Rmartin
Columbus, Ga, USA.
Thanks for the suggestions. I guess I've gotten so used to micro sanding, it's hard habit to break.
I ended up sanding and then building up a CA finish to get a smooth surface.
Drstrangefart
That's also an effective solution. One note: I ran into sanding issues with blue acrylic segment in bloodwood. The dust from the bloodwood deposited itself into the surface of the acrylic pretty deep from friction, and even cross-sanding followed by the skew didn't quite get all of it out.
KenV
Juneau, Alaska.
I often make little sanding blocks from tongue depressers, small pieces of steel, or similar so the surface is even.
Electric drill with the sanding disk like used on a bowls will keep things pretty even also
