William Young
I tried my first staghorn sumac pen today and I was not at all impressed with the color of it although I think I will keep this one. Then I tried a butterfly bush pen and it was worse so I stopped turning that one and took it off the lathe.
If I am in a hurry I use thick CA to glue the tubes and if I want to scrap a pen and salvage the brass tubes I just soak the blanks in a little acetone overnight and the tubes almost fall out.
But with these two, I used two part epoxy the night before. What is the best solvent for salvaging tubes after using cured 5 minute epoxy ? ? . I thought it would be better to ask here than to experiment with different ways.
I hope the answer is not scraping the wood off the tubes with a knife.
W.Y.
W.Y.
