Safety question regarding acrylic fumes
Rob77
Raleigh
I'm in the process of turning some acrylic blanks. I've noticed that these blanks put off a very strong smell when I turn them. I've set up a strong fan and I think my air circulation is sufficient. Is that enough?
I'm assuming the textbook answer is that I need a dust collection system but I'm only a part-time hobbyist and I only make maybe a pen or two every other month (and I'm on a bit of a budget).
Thanks for any advice you can provide.
TonyL
Georgia
Sadly, I am only doing this 4 weeks and about 3 weeks ago, I stopped noticing the smell. I own a dual vapor mask, but my glasses and goggles fog-up when I wear the mask. The same thing happens to me when I wear the light, white masks. I am going to wear it from now on though.
Jim Smith
Lakeland, FL
I'm pretty sure that my sense of smell is about as bad as my hearing, but that said, I always wear a Trend powered face shield when I am turning. The face shield is for protection from projectiles and the filtered ventilation was reduce the amount of dust and fumes that I inhale while turning. It has made a very big difference for me, especially when turning some of the woods like HRB that are more likely to irritate skin and nasal passages. In my experience, the filtered face shield was well worth the investment.
TonyL, The ventilation fans on the powered shields keep your glasses from fogging up.
Jim Smith
ashaw
Phila, PA, USA.
For the most part my dust collector extracts all fumes and dust. The only are is my chop saw. When I get a new shop all my tools will have dust collection ports.
TonyL
Georgia
I will get one immediatlely.
Jim Smith
I have a light cough all the time now. Which model and where please?
Old Codger
Bellingham, WA
Tony your concern and needs are the same as many of us who have this wonderful hobby/profession. Your comment about a 'light cough' is obviously not uncommon and I as many others worry about this... I have a Rikon air filtration system set up, plus a 20" box fan with a filter on it and run both all the time I'm working on the lathe, yet I still wonder if I'm fully protected. I open my garage doors and allow fresh air in as often as possible, but still know that several months of the year, weather conditions prevent this... I'm looking into an external ventilation fan but still wonder if this is enough to prevent problems... Comments/advice???
TonyL
Georgia
Thank you. I have an indoor workshop within a finished basement. Lucky and not so luck I guess. Like everything I do, I will research it, and go nuts finding a solution. All part of the journey :). Thank you again. You guys and gals are amazingly helpful.
Jim Smith
Lakeland, FL
TonyL,
Yes. I have the original Trend Airshield and find it comfortable and easy to use. The battery(ies) are located in the band at the top of the helmet and I always keep one on the charger and one working in the airshield in case one runs out I can switch them out and be back in business in two minutes. Here's another review of the two models that you can read. Also, I kept an eye out on ebay and bought mine new with extra filters and clear shield covers for considerably less than retail.
Trend Airshield Air Circulating Face Sheilds | After Hours with the WOOD Gang
Jim Smith
TonyL
Georgia
Amazon Respirator.
I use the resp o rator from amazon.
Amazon.com: Resp-O-Rator Dust Respirator Model JR-7: Home Improvement
It fits under my face shield or goggles, and I can just let it drop around my neck when I'm not turning. I don't use the nose clip...I don't have any problem not breathing through my nose.
Thank you Sharon. I will must likely get this until I research the more "advanced" types. I am 50 and don't remember the last time I breathed through me nose :). Thanks again!
JohnGreco
Sewell, NJ 08080
Use an MSA respirator ($35 on Amazon) with p100 filters, you won't smell a thing.
Does it have the anti-fog ventilator fan? I need to place an Amazon order.
I wear prescription safety glasses and a full face shield along with my half-face respirator, never had a problem with fogging, which was a CONSTANT problem when I wore the white paper style dust masks. I have been using mine daily (5-7 hours a day, M-F) for several years. So much that the elastic has worn out and I need to order another- yes, the same exact one. As good as the Trend is, it is not rated for the same level of dust safety. The filters I use (that it comes with, but you can also buy replacements) are rated for use with asbestos. Since I sometimes work with pressure treated, that level of safety is especially important for me. Your needs may be different.
TonyL
Georgia
I think I am going to get this one Jim. Can't beat the price! I hope it really filters the fumes.
Jim Smith
Lakeland, FL
TonyL,
That looks like it will solve the fumes issues but since it's designed to protect people using spray paint or other chemicals, I'm not sure if the sheild is rated to protect you from projectiles from the lathe. It may be, but I couldn't find that information in the specs. Just a thought...
TonyL
Georgia
I ordered it and the replacement cartridges. I have a shield and good quality safety goggles, so I am good. Thank you. I should have it by Thursday. I appreciate your help Jim and everyone else that contributed. :)
Rchan63
Framingham, MA
What about the rest of the people in the house. I assume the fumes will travel to the rest of the house. I also worry because my shop in the basement while the family is upstairs.
TonyL
Georgia
I agree with you.
My house is relatively large and no one goes downstairs (we bought the house with a finished basement). However , I will be buying a room filter. I am just doing my research. I care about my wife, son, and dogs more than I do myself...so I am with you on this! :)
kovalcik
Barrington, NH
Just my opinion, but I do not think the fumes from turning a cured blank are of any consequence. Plastic outgasses. If you buy any plastic item you get a smell, but there are no warnings to wear a filtration mask when you are opening your latest Amazon purchase.
Fumes while casting and dust while turning are concerns and should be dealt with appropriately, but I do not think turning a cured plastic blank is any less safe than turning a wooden blank.
TonyL
Georgia
Thank you! I can always skip the room filtration system for $400 and just buy my wife, son, and two dogs their own "masks" for $30 each! I wonder if they will fit the snout of a golden retriever :) . As my mom says, "It's easy to buy a pair of slippers that to carpet the whole world." I am teasing of course.
Darkshier
12265 s Strang Line Rd Apt 515 Olathe Ks 66062
So I was reading this thread last night and had the all might "Duh" moment. I've been having a persistent cough (not normal as I am a smoker) and have been to the doctor a couple times and was going to see an ENT about it. I've never used or thought about using a mask while turning and often get really close while doing fine details on my pens. I can't believe this never occurred to me. :bulgy-eyes:
WriteON
Florida & Pa
I'm using a 1.5 dust collector(with a 1micron bag) from PSI and I wear a Trend Air Pro. This stuff is expensive but much cheaper than a nursing home or funeral.
Jim Burr
Banned
Reno, Nv
I used this one for years. Remember...it can only function if it's on your face. With time, people revert to what's easier. If you have to put on 3 pieces of equipment before turning...how likely are you to maintain that behavior over time? The facts indicate not very.
JohnGreco
Sewell, NJ 08080
My workshop is in the garage, attached through a doorway near the kitchen. I have a section of kitchen counter with my respirator, earplugs, and prescription safety glasses. I put all 3 on before I step foot inside. I think if safety is important enough to you, you make sure to do whatever you can.
TonyL
Georgia
Hi Ethan:
Yes, I still use it. And I use it with this face shield :http://www.amazon.com/3M-Protection-82783-00000-Polycarbonate-Faceshield/dp/B007JZ1QQQ
I am not qualified to review it other than to say, I can't smell any odors/fumes, I don't believe I am inhaling any dust, both the "respirator" and face shield fit well...I don't get any eye glass fogging like I did with the white fiber masks.
Maybe there are toxins that I can't smell but continue to pass through the filters?
I don't have a sensitivity the fumes in terms of a allergic reaction.
I also have a dust collector (and an air filter which I bought in October and still have not taken out of the box). The that John T. posted is a good one and I did draw advice from it.
Lastly, I only turn pens; I don't make anything else. I probably make 2 a week. I hope this helps. There are many much more qualified folks than me to evaluate the protection of these devices.
I am happy with my purchases, but don't know if I am doing the best I can to protect my long term health.
endacoz
Brookfield, NY
Thanks for your review. It has been helpful as I begin to come to a decision, hoping that my health drives my decision and not my wallet...
WriteON
Florida & Pa
I worked as a dental tech for a lifetime. Spent all day working with acrylic and rarely used a suction(dust collector). I'm extremely lucky as I feel pretty good health wise today. I have a buddy did the same line of work. He breathed dust and fumes for a lifetime.....calls me one day to tell me about his lung transplant.
