Rounding Blanks
GregMuller
Miller Place, NY, USA.
I have started to round my blanks on a 1x42 belt sander prior to turning. Does anyone else do this and is there a reason why I should not. I have done it on everything from wood to PSI acrylics.
mrcook4570
Mason, WV, USA.
For me, the fastest way is to use the long point of my skew to round the blanks. Then I flip the skew over and turn to final dimensions.
Gary Max
Southern Kentucky
Greg it ain't going to hurt the blank any----I know a turner that uses a router to round his off first. Just watch your finger tips on the sander. Hurts like heck when you nick a finger tip.
Oak Ridge, NC.
" For me, the fastest way is to use the long point of my skew to round the blanks."
Stan,
I am trying to picture what you discribe and the picture isn't comming through the fog.
Please elaborate.
Mac
Ron Mc
USA.
Greg,
I round off all my segmented blanks to make sure that there are no corners or edges present when I put on the lathe.
JimGo
North Wales, PA
I find that for some of the more brittle materials like Lucite, rounding the corners can make things a lot easier. I have a 6" face plate that came with my lathe, and I attach some adhesive-backed sand paper to it and use that for some of the more precarious blanks.
wood-of-1kind
Toronto, ON, Canada
I at times use my roundover bit on my Porter Cable router to remove the blanks' edges. Using a fixture to hold the small blanks keeps my fingers at a safe distance from the sharp router bits.
-Peter-
vick
Gilbert, AZ, USA.
I once read something that made a lot of sense to me, but unfortunately I can not remember the source.
"You should always try to use the right tool for a job. The right tool for making a square piece of wood round is a lathe."
It is from memory so I apoligize if I messed it up, but it struck me as very true. I do round resin on my belt sander before turning just because it takes me so much longer to turn resin. I can also see people making very valid cases for rounding segmented, laminated or cross cut blanks. I use a 3/4 roughing gouge to round my blanks at a fairly high speed for almost all my wood pens.
Rifleman1776
Mountain Home, Arkansas, USA.
Originally posted by Johnathan
<br />It's going to end up on the lathe anyway, if it's a regular easy turning wood, I would pass the sanding step, just takes more time than needed.
A big 'yeppers' and 'me too' on what he said. That's what a lathe is for. Exception might be a big hunk of stump for a bowl. Best to saw as close to round as possible before putting on lathe. But a pen blank, high speed, sharp tools, light touch. Go for it.
mrcook4570
Mason, WV, USA.
Originally posted by Mac In Oak Ridge
<br />" For me, the fastest way is to use the long point of my skew to round the blanks."
Stan,
Please elaborate.
Mac
With the blank spinning on the lathe, I lay the skew on the tool rest and slide it so the long point enters the blank. It will (very quickly) eat through the blank. After it is round, I use the skew in a normal manner to finish turning the blank. This has really helped my efficiency. I first read about this on the web somewhere, but I can't remember where.
