Round blanks
jbeyer
Maryland
I just got some 3/4" tru stone blanks. I wanted to know what the size goes down to when it's rounded enough to go into a collet.
Jonathan
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
This may be a dumb answer, but theoretically, if you turn it perfectly between centre then you should still get 3/4 round:wink:
sefali
Philly
It would depend on how accurate their measuring, and your centering are. A perfectly square 3/4 blank, mounted exactly on center, could be turned to 3/4 round. In reality, I'm sure that's a relative rarity. Figure on just slightly under 3/4.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Jonathan
Have you measured them to see what their REAL dimension is?
That will determine what you can hope for. Your "center marking" will determine what you GET.
SteveG
Eugene, Oregon 97404
If you are going to drill the blanks on the lathe you can turn them down to desired 3/4'' size, leaving some small flats on the blank, and they will drill just fine, leaving you the max size on the blank for the next step.
