It's all about what works best for you. Many people can get a really nice finish cut with a skew. Many people have nothing but trouble with a skew. If you're careful to ride the bevel, you can get a nice finishing cut from a gouge. Some people like scrapers.
Since you're a self-described "rookie", I suggest you try different tools. You can do this once your blank is round, but while it's still oversize. You can get a feel for how much control each tool gives you. How fast does it cut? How evenly? How good a finish? The right answer may vary by the material. Once you get close to your target size, switch to the tool that you feel most comfortable with, and don't worry about whether one of the others might be "better".
The "best tool" will vary as your skills grow. If you really want to boost your skills, be sure to practice whatever you feel weakest on. You can practice on scrap, or on actual projects while they are still well oversize (so you can use your "comfortable" tool to clean up any mistakes).
