| Penturning General penturning discussions not specifically addressed in one of the specialty forums. |
LinkBack | Thread Tools | Display Modes |
#3 (permalink) |
The good is that there is no black plastic ring like the old Cambridge. Additionally , the plating quality seems equal to or better than Cambridge. The Roman Harvest fountain can frequently be purchased for less than $20. The Cambridge fountain is over $30 and is the same price each for 1 or 50.
The bad part is the ink pump on Roman Harvest is "Hit or Miss" quality. Another bad thing is that with 10 sets of hardware I got 7 different caliper reading on the inside tube diameters. Some tubes fit so tight that the inside tube diameter had to be filed down in order to build the set. Others were so loose that they required epoxy to be built. Over all, I think it is worth taking the chance on Roman Harvest. The tubes can be made to fit properly with just a forewarning. As best I can find, it is at least $15 per set less than Cambridge.
__________________
Andy Little
entia non sunt multiplicanda praeter necessitatem. The popular interpretation of this principle is that the simplest explanation is usually the correct one. -Occam's Razor Common sense isn't always such a common thing. If it ain't broke.......then a little duct tape won't hurt it! ![]() Last edited by PenMan1; 02-04-2012 at 09:33 AM. |
#4 (permalink) |
Craig; I'm working on my first one, so I'm interested in this too!
It looks good at this point, but the tubes are slightly different sizes than the Cambridge, so you will need to get bushings and make a sleeve for the tubes.
__________________
Randy S.
I have a written set of life rules: 6. A person (politician) who speaks of sacrifice at length is talking about someone else, not themselves. |
#5 (permalink) |
Has anyone tried the Cambridge tubes on the Roman Harvest sets? :)
__________________
Andy Little
entia non sunt multiplicanda praeter necessitatem. The popular interpretation of this principle is that the simplest explanation is usually the correct one. -Occam's Razor Common sense isn't always such a common thing. If it ain't broke.......then a little duct tape won't hurt it! ![]() |
#8 (permalink) |
If the Cambridge did not have the black band, would it be worth the extra cost, over the Roman Harvest?
__________________
Ed Brown - "Resinator"
![]() "Often copied....NEVER duplicated!!!" click here to see what's NEW at ExoticBlanks.com! "If you have not visited today, you are missing new things!!"![]() |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
