gtanajewski
When assembling the above kits from Craft USA you are required to make a small notch in the finished end of the cap blank so the cap & clip will set flush. I have tried a small 1/8’ chisel and a rotary tool as they suggest but I am not happy with the finished product. The clip never seems to fit in the notch the way it should. All suggestions welcomed. Do kits from other sources require this notch?
Corbitt
Corbitt
