Rollerball Click pen - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 07-10-2017, 06:58 AM   #1 (permalink)
Photos: 6
Question Rollerball Click pen
Does anyone know of a click pen kit that will accept a rollerball refill. I have a customer that is looking for one. If not, is there a rollerball refill that will fit in a standard click pen kit?
Gnome De Pen is offline   Reply With Quote Top
Old 07-10-2017, 07:36 AM   #2 (permalink)
Photos: 4
Default
It is my understanding that you will not generally find that because of the liquid nature of the ink in a rollerball. It needs to be capped to keep the ink from drying out.
Talltim is offline   Reply With Quote Top
Old 07-10-2017, 08:28 AM   #3 (permalink)
Photos: 1
Default
I'd ask them to try a Schmidt EasyFlow to see if they like it. I was surprised to see how close it is to rollerball performance.
gtriever is offline   Reply With Quote Top
Advertisement
Old 07-10-2017, 11:06 AM   #4 (permalink)
magpens's Avatar
Photos: 67
Default
The rollerball refill is about 0.4" longer than the Parker ballpoint refill.
The rollerball refill also has a tiny plug insert at the top end.
If you were to cut "about" 0.4" off, and replace the plug insert, it would fit .....
..... HOWEVER .....
1) the design of the spring end of the refill is different and the spring may not fit right
2) you may have to make a thin cylinder of plastic/metal for the spring end to work right
3) ... AND ... the nib end will be exposed in the ballpoint design and the ink will dry out
4) ... AND ... the exposed/uncapped nib end might leak rollerball ink into pocket/whatever
So, although the rollerball refill could possibly be physically made to fit, this may NOT be desirable
A better approach would be the high quality Schmidt refill mentioned above.
There may be other refills that will also work; consider Uni-Ball #207.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 07-10-2017, 11:40 AM   #5 (permalink)
RKB
Photos: 0
Default
Here is a link for refills that may help you.
https://www.cultpens.com/c/q/explore...ype-g2-refills
Rod
RKB is offline   Reply With Quote Top
Old 07-10-2017, 01:12 PM   #6 (permalink)
KenV's Avatar
Photos: 0
Default
I have several shirts with large ink stains from wicking from rollerballs. One reason for caps is the stains are hard to remove and one needs a limited number of shirts suitable to wear while painting.
I have adapted a rollerball to click as a challenge, but there is not a replacement schema and a one time use pen is not going to be especially sales attractive. And if put away with the tip out, there is the wicking potential.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 07-10-2017, 03:03 PM   #7 (permalink)
Photos: 0
Default
I had good success with this refill in the same scenario.
Rod
__________________
I firmly believe that any mans finest hour, the greatest fulfillment of all that he holds dear, is that moment when he has worked his heart out in a good cause and lies exhausted on the field of battle victorious.
- Vince Lombardi
epigolucky is offline   Reply With Quote Top
Old 07-10-2017, 09:01 PM   #8 (permalink)
budnder's Avatar
Photos: 2
Default
Obviously I'm not your customer, but I went down a similar path last year ( Rollerball Click Clone thread ), and ended up deciding a Parker 9000 refill was close enough to a rollerball. I haven't given up completely on a custom clicker with a rollerball, but it's on the "when I have time" list.
__________________
Roy
Life is too short for a boring pen...
budnder is offline   Reply With Quote Top
Old 07-11-2017, 07:51 PM   #9 (permalink)
Photos: 1
Default
There are, as mentioned by others, ball point refills that wright about as smoothly as rollerball pens there are also gel ballpoint refills that write very smoothly. And rollerball pens really do need to be capped.
Quote:
__________________
Smitty37
Passing from this life is not the end - it's the beginning
Smitty37 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
click pen , kit , rollerball
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
