Ozzie
Some questions for the experienced penturners. Has anyone made the Rockler Round Top European Pen, Stock #20114? They had a sale about two months ago and I bought some kits to try them. (I have only turned about 20 pens, all Slimlines up to now.)
The instruction sheet that came with the kit is vague and I hope you can answer these for me. One of the tubes is longer than the other and is that the lower or upper part of the pen?[8]
The pictorial shows the center ring as being free but the ID is too large for it to go on the twist mechanism. Do you attach it by glueing it or do you leave it free floating? Are there any better instructions out there somewhere?[8]
The Bushing Kit, Stock #29973 has three different sized bushings/spacers. Which one goes where on the mandrel?
Are the bushings/spacers in the any kit, not just this one, a guide to the proper dimenstion the blank should be turned to?[?]
Finally, a question for Bill Young if you should read this posting. You used Aleene's glue in some of your other endeavers(sp). Do you think it holds as well as the yellow wood glues? I am thinking of using it to edge glue some 1/2" boards about 15" long to make some scroll saw pictures for Christmas presents.
Thanks for any help you all can give me.
