Riddle Me This.... - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 06-26-2018, 08:04 PM   #1 (permalink)
ladycop322's Avatar
Photos: 0
Default Riddle Me This....
Okay friends and gurus, I have a mystery I need solved.
I made a set of blanks a couple years ago. Still sitting here and now I have no idea what kit they go to.
These are the measurements: Top barrel/cap is 1.987" with an ISD of .5285 and the bottom barrel/body is 2.253" with an ISD of .403...
I have inputed these measurements in IAP app and met with negative results....anyone out there can help me identify the kit these belong to?
I know not the Gent or Stateman because bushings too big.
Also not the Gent II
Anyone?
ladycop322 is offline   Reply With Quote Top
Old 06-26-2018, 09:21 PM   #2 (permalink)
magpens's Avatar
Photos: 75
Default
I just measured a tube set for an Emperor:
Top: Length = 1.953"; ISD = 0.552"
Bot: Length = 2.265"; ISD = 0.435"
Full size Gent, Statesman, and Majestic would have same diameter tubes but slightly different lengths.
For example, Full size Gent:
Top tube length = 2.05"; Bottom tube length = 2.37"
Majestic would be:
Top tube length = 1.97"; Bottom tube length = 2.15"
That's as close to helping you as I can get. . I am taking the Gent and Majestic numbers from an old 2010 table that Wayne R. compiled. . I can email you a copy of that table (10 pages or so) if you think it might be useful to you.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 06-26-2018, 09:37 PM   #3 (permalink)
Photos: 0
Default
I have two Cassuis Div Roller ball kit from Lau Lau pen in Hawaii that meet you specs.
cheers
Charlie
Dieseldoc is offline   Reply With Quote Top
Advertisement
Old 06-26-2018, 10:54 PM   #4 (permalink)
jttheclockman's Avatar
Photos: 83
Default
Look at all the bushings you have and start there. If the bushings fit then you maybe able to narrow it down. I am sure you were not making a pen without the bushings unless you do between center turning with no bushings.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 06-28-2018, 08:45 AM   #5 (permalink)
ladycop322's Avatar
Photos: 0
Default
I don't have the bushings...need to know the kit type before I can use the correct bushings ;)
Old 06-28-2018, 09:01 AM   #6 (permalink)
pianomanpj's Avatar
Photos: 51
Default
Any idea of the thickness of the brass tube? Might be easier to track this down if we knew the OSD of the tubes.
__________________
Roger A. Madore
Augusta, Maine
"Make a fire for a man and keep him warm for a day, or set him on fire and keep him warm for the rest of his life..."
pianomanpj is offline   Reply With Quote Top
Old 06-28-2018, 11:16 AM   #7 (permalink)
Photos: 83
Default
Anyone?
My point here is why would you make a set of blanks for a kit you do not have bushings for??? That does not make sense. I know you make blanks to sell, were these for a client or yourself?? If a client maybe you have the order paper and on it is the kit name. If for yourself would you not have bought the kit with the bushings if you planned on turning for yourself?? Unless you had the bushings already and just bought extra tubes or kits. I have over 1000 kits and have bushings for everyone.
I am sure you store your bushings in some sort of reference order so start there and check all the bushings you have that are for a 2 piece kit. Again I maybe missing something and it makes no sense to have tubes and make blanks for a kit without the proper bushings unless it is for a client and then I can understand it. This is all I am saying. I do not believe there is any chart that gives inside tube dimensions.
__________________
John T.
Old 06-28-2018, 02:27 PM   #8 (permalink)
More4dan's Avatar
Photos: 5
Default
Anyone?
The bushing dimensions in the chart will be very close to the tubing ID, slightly smaller than the tube.
More4dan is offline   Reply With Quote Top
Old 06-28-2018, 02:48 PM   #9 (permalink)
More4dan's Avatar
Photos: 5
Maybe recheck the body tube ID. If its .430 not .403 I have a couple matches. Lotus screw cap, Imperial screw cap (aka Bamboo). The tube length is closer to the Imperial (Bamboo) 1.90 cap and 1.97 body. The database showed body bushing ODs (tubing IDs) jumping from 0.389 to 0.427 with nothing in between.
I have an Excel version of the IAP bushing table. Let me know if I can help further.
Danny
Old 06-28-2018, 02:58 PM   #10 (permalink)
More4dan's Avatar
Photos: 5
Default
If I filter by lengths instead of IDs I get Emperor and Oriental Dragon with cap upper bushings OD of .547 in tube and body bushing 0.427 in tube portion. The tube ID would be about 0.005 bigger than the bushing.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
