Randy_
I just saw an ad for this stuff in a new magazine and was wondering if anyone has tried it? Apparently, it is a polyurethane glue with a relatively short set time. The manufacturer claims the initial set time (clamp time) is 40 minutes; but this can be reduced to 20 minutes by dampening the mating surfaces. The cure time for max. strength is 8 hours.
They also indicate that the glue is quite thick so it doesn't have the tendency to run all over the place like thinner glues. I did not see any comments about bubbling and expanding; but I think it does.....at least a little.....because there was a comment that clamping should be tight to keep the glue line thin. And that wide glue lines where the glue had expanded into a wider joint were more porous and not as strong as a thin glue line.
(Makes me wonder about using polyurethane glue when there is a sloppy fit between a pen tube and a blank.)
RHINO ULTRA GLUE
RHINO ULTRA GLUE
