DKF
Has anyone had any success at removing a tube that has been glued in with CA? I would like to save a closed end lucite in which the tubes/blank need to be painted. Thanks for any and all advice.
I had to do this the other day. I mounted the blank in my centering vise and used the drill press with a junk same size drill bit. Just be slow. Usually it will grab the tube and break the glue bond when it first starts out.
I wear a face shield when I do this since it is a little on the dangerous side.
Now THAT'S funny! :biggrin::biggrin::biggrin:I was able to remove a tube by applying a combination of all the techniques listed here in careful succession, followed lastly by smashing the blank/tube with a hammer!! Tube came right out!
