I've just had to repair a pen set I gave to someone some time ago as the wood had cracked and even split in one place. As best that we can make out it was caused by moisture movement in the wood, as there is a wide range of both temperatures and humidities where they live. I can only assume that the outer surface of the wood, and it's ends moved but the inner surface couldn't because of being glued to the brass tube. I used CA to glue the tubes and cellulose sanding sealer followed by carnuba wax as a finish by the way.
I have been asked to turn some more pens but in Bethlehem olive wood. I have had troubles with olive wood bowls in the past and so am worried that I will have a repeat performance with pens so what would be a better way to treat the wood please, given that olive wood can be naturally oily? Would an elastic glue such as polyurethane be better on the tubes and if so, will it stick to oily wood? Should I seal all of the wood including the ends with such as CA? I really do need some help here please!
TIA
Tony Wells.
TIA
Tony Wells.
