refill for Barons
LanceD
Houma, La, USA.
I much prefer the Pilot G2 refill. I have noticed on many of the refills that come with the Barons they skip after a little use.
Dario
Austin, TX, USA.
That is why I am referring him to Charles, Schmidt is much better than Hauser in my experience.
Haven't tried Pilot G2 refill yet but I bet they are nice too...I love Pilot pens [;)]
Borg_B_Borg
Castro Valley, CA, USA.
There is only one issue with using a Pilot G2 in place of a Hauser or Schmidt. The G2 is shorter than either a Schmidt or a Hauser by a millimeter or so, not enough to hamper its functionality, but enough that it becomes noticeable when installed in a pen. This can be corrected by either trimming down the shoulder of a G2 or by drilling away part of the internal portion of the pen. The latter solution would unfortunately render a standard Hauser or Schmidt too long for the pen.
Steve
Dario
Austin, TX, USA.
Originally posted by Borg_B_Borg
<br />There is only one issue with using a Pilot G2 in place of a Hauser or Schmidt. The G2 is shorter than either a Schmidt or a Hauser by a millimeter or so, not enough to hamper its functionality, but enough that it becomes noticeable when installed in a pen. This can be corrected by either trimming down the shoulder of a G2 or by drilling away part of the internal portion of the pen. The latter solution would unfortunately render a standard Hauser or Schmidt too long for the pen.
Steve
Hmmm...for this, I will never use Pilot G2 refill then.
JimGo
North Wales, PA
I use the Montblanc refills. The tip is a little wider than the Schmidt or Hauser, but I've successfully used it in a Jr. Gent and a Ligero. My Ligero doesn't show any difference between the refills, but on the Jr. Gent it is apparent that it doesn't fit properly because the writing tip doesn't QUITE extend out as far as with the Schmidt/Hauser refills.
FWIW, I sold a Havana with a ballpoint refill to my cousin. I bought some standoffs at HomeDepot and cut it to the appropriate length, and slid that over the refill to create an artifical shoulder. He specifically asked about a ballpoint, otherwise I wouldn't have done such a cluge, but he's aware of the need to use the standoff on all future refills too. I figure I'll be making some new standoffs for him in a few months, but that's what you do for family!
Jim Boyd
Montgomery, Texas, USA.
Steve
Something sounds backwards here[:D]
vick
Gilbert, AZ, USA.
[/quote]
[/quote]
I though I was not getting something glad to hear I am not the only one.
Call me a hack but I would tend to try to shorten, stretch or replace the spring if I wanted to make a different refill fit better.
Borg_B_Borg
When I said a G2 is shorter in my previous post, I was referring to the distance between the tip and the shoulder of the refill. It's not something that can be corrected by simply inserting a longer spring or shim, etc. because the refill is already extending as far as it can in the pen. Like I said before, one way to correct it is to trim the shoulder down on that particular G2 refill, but this will have to be done every time a new G2 refill is used. Or you can modify the interior of the pen(I haven't done this on mine) so that the shoulder of the refill can seat further down the tip of the pen.
Steve
Originally posted by vick
<br />
Rifleman1776
Mountain Home, Arkansas, USA.
Originally posted by Old Griz
<br />Your local office supply store should have them.. they are common rollerball and fountain pen refills.
I am yet to find an office supply store that has access to Hauser or Schmidt refills, including Office Depot, etc. Nor can I find them with internet searches. I think those are just ficticious names. [:p] The Zebra JF works also and is acceptable.
Ron Mc
USA.
I replace my Hauser refills with the Schmidt 888F from TangBoys site. I'll be darned if the name is lost in my feeble mind but I imagine he'll jump in here at some point.
Good product and good service.[;)]
gerberpens
Arkadelphia, Arkansas, USA.
I too have purchased Hauser refills at Target for $.99. That is the lowest price anywhere. I beleive the Baron comes with a Hauser 707 refill and Target carries the Hauser 777 refill. But for $.99 I carry them for my Baron customers who don't want to travel to Target. I haven't had any complaints.
Rifleman1776
Steve
I have one in my personal Baron right now. Went in without problem and is OK.
Rifleman1776
More info on the Baron refill problem. I say problem because the Hauser and Schmidts seem to be myths. Have checked with all the big office supply stores and even Target, none have them. I have found the following information as to what refills fit the Baron rollerball:
Hauser 707 and 777
Schmidt 888
Pilot G-2
Zebra JF
And today I received a reply from Cross customer service. According to them the follwing are also compatible:
Cross 8521 (blue) and 8523 (black)
mrcook4570
Mason, WV, USA.
It's a standard rollerball cartridge. Many companies make them. Sailor, Schaeffer, Schmidt, Hauser, Cross (rolling ball), etc. Staples, Office Depot, and Levenger's all carry their own generic brand as well. But the generic ones, IMO, are not very smooth.
ccarse
Lithopolis, OH, USA.
Why is that? They are what come in pens and can buy them readily on the internet. I just ordered some from http://www.woodchipshome.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=WC&Category_Code=SCHM the other day. What is so mythical about them? Maybe I am misunderstanding your statement.
Rifleman1776
Originally posted by ccarse
<br />
Thanks for that link. Of course, my comment is an exaggeration. But that is the impression I got after checking with numerous local office supply stores and several of the large, nationally known, office supply outfits and the big discount stores. No one has them or can even order them. 'Tis a puzzlement, indeed. And it has the potential of making pen customers upset when/if they cannot buy refills. I'm not interested in just a source for myself, it is the end-user customer I'm thinking about. I note even Wood Chips is out of stock. Maybe they really are just a myth.....[;)]
Rudy Vey
South Plainfield, NJ, USA.
If you go to any office supply store, take the refill with you and show them. The type is pretty standard and they should not have any problem to help you. If you want the brand that come with the Barons, you can get them from Berea. But you can also use the Schmidt refills that come with Gents pens. They can be found either here:
http://www.theinkflow.com/schmidt_cat.htm
We also had a group buy some time ago, IIRC last fall, and they were a little as $0.35 a piece for the good quality Schmidt refills. I think the link was listed here too, woodchips, or so.
Both the Hauser and the Schmidt are good quality refills, and I even bought no-name brand in office store that worked fine.
Originally posted by dscott
<br />does anyone know where can you get refills for barons
Rifleman1776
Originally posted by Rudy Vey
<br />If you go to any office supply store, take the refill with you and show them. The type is pretty standard and they should not have any problem to help you. If you want the brand that come with the Barons, you can get them from Berea. But you can also use the Schmidt refills that come with Gents pens. They can be found either here:
Rudy, I have made the rounds of more office supply stores than I have previously visited in the past ten years. I even braved the crazed drivers in Little Rock during rush hour. None to be found.
