Refill
Irish Pat
Ireland
Have a problem with a sierra pen.When I assembled it I have the tip of the refill coming out to far,(I know what I did,cut tube slightly too short)Is there anyway of solving this problem.?
Ambidex
Bristol NH 03222
Plain sierra or clicker? I just put a clicker together that the click mechanism wasn't seated all the way and had to (gently) force it seated in assembly.
mbroberg
Columbus, OH
If it is a twist sierra you can cut the body down to 1.88 and make a click sierra out of it without using that little silver extension. Then take the tube from your click sierra kit and have another go at your twist.
Millersburg, OR
I don't know if you have them there but a zebra refill is shorter than a standard refill. You will have to trim the tube shorter. The tip is also a tad thinner as well.
RBcarving
Shell Knob, MO
If your tube is really too short, you could turn a couple wooden spacer centerbands and add one to each end of the barrel, next to the current band.
Brad
LagniappeRob
New Orleans, LA
I'm confused. Tube length doesn't affect how far a Sierra refill comes out. The transmission and premade nib end do. You could simply put the clip end on the other pieces and a Sierra works fine with no body at all... I've done it a couple time while needing a pen to write with in the shop.
StuartCovey
Rogers, AR
The refill is controlled by the transmission and lower section of the pen - the tube length cannot affect that. Is there something stuck in the transmission or on top of the refill?
If not one of those things, it is not a Sierra.
This is true. Make sure there is nothing stuck in there. Are you using the supplied refill? If you are using a refill that was not supplied with the kit make sure it is the correct size.
Like he said "if its not this its not a Sierra".
