William Young
I have a question for anyone with the Reeves Drive system that is on so many makes and models of lathes nowadays. . In the outward end of the shaft is a threaded hole. Is there a handwheel available that can be fastened to that? My Mini lathe had a handwheel and I used it all the time for small turnings. In the near future I am going to make a bunch more pens and smaller turnings on my full size lathe and I need a handwheel on that end. I need to rotate the handwheel while applying my laquer finish. Even just sanding with the grain between grits requires a handwheel.
My particular lathe has the ten speed Reeves Drive so I do not know if the shaft and threaded hole size would be the same on the five speed ones.
W.Y.
W.Y.
