Red and white stripe blank issues
mmayo
Tehachapi, CA
Any advice for a vendor for red and white stripe blank that is easy to turn. Two blanks in a row turned poorly and that is usually not the case. Sharp, fresh carbide and care still resulted in serious chipping. To get a pen completed I resorted to sanding, yes I will stand in the corner. The blue and white stars blank turned easily and smoothly. I bought the blank from either WoodTurningz or Penn state a long time ago.
It appears like all vendors sell the same blank.
ed4copies
Local Chapter Manager
Racine, WI, USA.
As far as I know, there is only one place that makes that blank. Some of them are great, some...........not so much.
OZturner
Sydney. NSW. Australia
You can come out of the corner, Mark.
Sanding is a means of obtaining a Smooth Removal and Finish, as such the Concept of "What Ever It Takes" does apply.
I am not a Carbide Turner, I like the Skew, as it presents a "Cutting" edge, at an angle, to SLICE material from the Blank. Where as a Cutter be it Carbide or HSS presented along the axis, of the object, is really a scraper, and depending on the nature of the Material, it can either shave it off, or it can chip it off.
Have you tried using a Sharp Skew on this material?
Regards,
Brian.
mmayo
Tehachapi, CA
I think the term sharpening challenged was coined for me, but I plan to try MagicBob's carbide skew. A real skew is coming too.
Good news the one I sanded will be in on sale tomorrow and looks like it will not gather dust.
MTViper
Clyde, Texas
I've never been a skew guy. Ii know how to use it, just don't like it as well as other tools - personal preference. I went through carbide tools on acrylics and didn't like the results. I finally got a 3/4" SRG from PSI to use on acrylic pens and it's wonderful. I keep it very sharp and use it just like I do it's bigger cousin on wood. Gives me a nice smooth finish, usually to completion.
Sandpaper is a tool, if you need it, use it and don't stand in the corner.
MTViper
Clyde, Texas
That's a 3/4" Spindle Roughing Gouge (SRG), the little brother to the one I use on my wood pens. I got a Benjamin's Best and have been totally happy with it, sharpens easily and holds an edge nicely. And it was on sale when I bought it.
mmayo
Tehachapi, CA
I just turned 8 two tube acrylic acetate pen blanks and 6 wood Sierra blanks including ebony without issue with a 2" radius carbide tool.
The red and white material acts like I inlace acrylester, which I dislike. I have made pens with it, but it is somewhat unfriendly.
