Red Palm...................?
TurnerJohn74
West Branch MI
Hello everyone! I was just wondering if anyone knows any secrets to turning Red Palm. I cant seem to keep it on the tube:frown:. As soon as I touch my tool it cracks and comes off the tube. I would love it if someone could tell me the secrets? Thanks.
Lenny
Searsport, Maine
Did you glue it with CA glue?
If so try gorilla glue or 30 min. epoxy instead.
Be sure to sand the tubes lightly to rough them up so they will grab.
But maybe you know all that and I'm off base here ...?
Beyond that, sharp tools and go slow and careful.
Robert Taylor
North Canton, Ohio, USA.
keep in mind that red palm is not wood, it is grass. with that said use sharp tools and harden with ca glue from the start ca glue, turn, more ca glue, turn, more ca glue, and you should be fine.
jskeen
Crosby, Texas, USA.
Like all palms, it is composed of dense fibers surrounded by a matrix of fairly soft open cells, which when alive, transport liquids via osmosis and support the trees respiratory processes. When dried this matrix is very soft, often crumbly, and the fibers become extremely hard and tend to splinter.
To turn you definitely need to reinforce the matrix with thin ca, and be sure to cut the fibers so that the cut is "pulling" them against the longest area of support. Not sure quite how to explain that, but you don't want to "push" the fibers, or they tend to pop out. After I get rounded, I usually tend to switch to the dreaded 80 grit gouge for shaping.
David Keller
Enid,OK
Lots of thin CA, light cuts with a sharp tool, always cut with the grain(generally cutting from fatter to thinner on the blank). Also, don't be ashamed to use the '80 grit gouge' to get it to finished diameter and shape.
TurnerJohn74
West Branch MI
Thank you all for the info. The CA thing makes sense. Thin coat turn thin coat turn and so on. The 80 grit gouge sounds like it would work perfect.
rjwolfe3
Mansfield, Ohio, USA.
Great info listed. I have a hard time with it myself. Ticked me off many times.
Another plug for the wood info chart. These posts are just the reason that we need it!
jskeen
Crosby, Texas, USA.
could you "stablise" with something other than CA glue?
Depends on the quantity you were doing. Palm is heavy, so would be expensive to send out, as most processors charge by finished weight. If you have enough to batch process, you could home stabilize with either vacuum or pressure or both, but for one or two blanks it's probably cheaper and faster to us the CA.
