Red Oak Crossed with Corn Cobb
jashton
Willis, Texas, USA.
I got the idea today of stacking a piece of Red Oak with a stabilixed Corn Cobb. I cross cut them, then reverse glued. I turned the pieces and believe it or not turned out well.
At about 3000 grit micro mesh I used a blue sharpie marker to stain.
I was suprised at the outcome. Has anyone done anything, like this if so .....do you have any hints.
Feed back is welcome and wanted.
jashton
Willis, Texas, USA.
Image Insert:
jashton
Willis, Texas, USA.
I am a new member and having trouble with downloading pics to the site that will fit. Any help would be great.
The one I got to fit is to small to even see.
karlkuehn
Banned
Lancaster, Pennsylvania, USA.
Very interesting, Joe!
I use Prismacolor art markers all the time to dye my blanks on the lathe, although I do it after I've sanded all the way through MM12K and before the CA/BLO. It helps to give them a little DNA rub with a soaked paper towel to help the coloring sink in after you've rubbed it on.
As for the pic size, there's a limit on how big a file you can upload. I use my own server and just post reference photos inline, so I'm not much help there.
Hello
Brattleboro,VT, USA.
a little erie.....on my way to work this morning I was thinking about making those celtic knots....what I might do to beging practicing the necessary cuts. A passing thought had run through my head of laminating a couple of angled sripes of ebony into a stabilized corn cob...then I get to work and check IAP to find that you've done something similar! very creepy!
here's my $0.02 on the pen....I like the idea, and I dig that you tried it, but I don't really like the result in this particular case. maybe dying the cob red to sorta' go with the red oak would work?
Rmartin
Columbus, Ga, USA.
You're probably having a problem with the resolution of your pic rather than the size. A large "optimized" pic will go through when a small hi-resolution pic won't.
