latech15
After seeing the pens turned out of lucite from pipe makers emporium I decided to try a few. I got two caramel ripple sticks and one clear stick.
I cut off some blanks for a cigar pen from the clear stick, drilled the blanks and painted both the inside of the tube and the brass ford motor company "engine blue". Let the paint dry and glued the brass inside the lucite. Trimmed the ends turned and sanded, buffed and removed from the mandrel.
I pressed the components in for the lower end and everything went fine. I (by hand) started pressing the lower piece into the upper blank and the brass tube slid out the top(clip end)! The glue bond broke.
I did not rough up the brass with sandpaper before I painted the tube and glued it in and I know that this probably would have made the brass stay in the blank, lesson learned.
I went ahead and pressed the components into the top piece and pushed the brass back into the blank. The components stayed and feel just as solid as any other pen I have made.
It wasn't until 3:00AM that I realized what I had seen..... the brass tube came out the top. Not the brass tube with the blue paint on it. It was shiny new brass. I guess that when I glued the tubes into the blank the paint on the brass sealed to the paint on the inside of the blank. It was like the brass just slid out of the paint.
The pen turned out great. There are a few flaws in the paint but all in all it is nearly perfect. I have been using it today and the clip does not feel loose or anything and the finish is crystal clear with very minor imperfections.
As I said, I used Testors model car paint from Hobby Lobby. Anyone know if the CA glue would have a reaction with the paint that would make it release from the brass or why this happened? It was not like the paint had scraped off in a section, it was like I was looking at a brand new brass rod that had never had any paint on it.
Weird!!!
Weird!!!
