Hey Guys, My question is; how do you modify the length of the refill in a slimline? Thanks.:smile:
JBCustomPens Member Joined Oct 3, 2009 Messages 717 Location Everett, Washington Jan 4, 2010 #1 Hey Guys, My question is; how do you modify the length of the refill in a slimline? Thanks.
JBCustomPens Member Joined Oct 3, 2009 Messages 717 Location Everett, Washington Jan 4, 2010 #2 I had heard somewhere about removing the black plastic screw-in part, then cutting the refill? Is that right? Thanks again?
ed4copies Local Chapter Manager Joined Mar 25, 2005 Messages 24,527 Location Racine, WI, USA. Jan 4, 2010 #3 Adjust the depth of the transmission, then "stock" refills will fit in the future. If you cut your refill, you will have to do this every time you change the refill.
JBCustomPens Member Joined Oct 3, 2009 Messages 717 Location Everett, Washington Jan 4, 2010 #4 Thanks Ed!
