Quick finish for Bic stick pens
wb7whi
Spokane WA
Anything you want. I like stain and oil but I also dye and even burn them sometimes. Lately I have been carving the tops and using spray lacquer to finish.
okiebugg
Jenks, Oklahoma
Bic Pens
For starters, I like to use Acetone/Plexi as my primary finish IF they are not too ornate.
If too ornate, Deft Lacquer. The lacquer has a tendancy to amberize the wood slightly.
The Acetone/Plexi gives you true color of the wood
refueler1
Indiana
How long does it take the acetone/plexi to dry? I was looking for something that drys pretty fast. I tried thin CA but it just soaks in and takes way to much to build up.
okiebugg
Jenks, Oklahoma
When applying correctly. new applications dry instantly so you can put on another coat in a few sectonds. Coats later take a few minuutes to dry. When you have built it up and are finished, overnight before sanding and polishing
refueler1
Indiana
Anyone sell the Bic pens they make or just give them away. I've had several people want some and told them $5.
JohnU
Ottawa, Illinois
Thin is nice for sealing and a starter coat, then use the medium to build layers. If the wood isn't too pourous it wont take but a few coats.
refueler1
Indiana
So far I have been using scraps of Spalted Beech so they are porus. I like the spalted woods since they have the black lines in them but they are pretty porus. Might have to try some cherry and none spalted maple and birch.
