Joe Melton
I've read, I think, all of the postings about bullet pens and have some questions.
1. What weight of bullet should be used? I've seen these in weight of 75 grains and up, with common sizes in the 155 grain range.
2. Some turners use bullets and others use the nibs from the kits. If using the supplied nib, how does one determine beforehand what diameter the brass is where it will fit against the nib? I guess an ancillary question would be "what kit should be used with what caliber of brass?"
3. I see in Don Ward's excellent tutorial that he uses a hollow-point bullet and uses the hollow to locate his drill. Why can't the bullet be drilled from the other end in a lathe? This would be more accurate, I'd think, and also would allow the use of "un-hollow-point" bullets, which cost less.
4. How does one measure to assure the bullet is pressed the correct distance into the brass, after the bullet is drilled? Since the transmission is pressed in first, is the bullet then pressed in in increments, while testing with the ballpoint cartridge installed, until the tip sticks out the correct amount? I'm used to pressing the transmission in in increments, because the mark on it is not always accurate enough.
5. Do new brass always come without a primer?
6. Will a 308 bullet fit a 30-06 brass?
7. I see that some bullets come in a "boat-tail" design. Are those better or worse for our use than those with straight sides?
Sorry if these questions are stupid. And, thanks for helping.
Joe
Joe
