GregMuller
After turning my first pen and trying to assembly it I have some questions. This was a slimline pen. First problem was that everything was loose in the tubes. The nib, the turning mechnisim all were loose and would not advance or retract the refill. The only thing that was tight was the finial that held on the clip. I suspect the culprict was the barrell trimmer but am not sure. The one I have goes all the way into the tubes. I know it is supposed to clear excess glue but is it possible it expandes the tubes if there is some wobble in the drill press? Also is the centerband supposed to be loose or does it get pressed onto something? Can you all let me know what i possible did wrong.
