Freethinker
I have made a pen with just about every style of segmenting that I know of......celtic knots, 360 herringbone, various Kallenshaan laser blanks, brass and aluminum sandwiched between wood and acrylic, but I have just now made my very FIRST scalloped-end blank........and now I am pretty anxious about drilling it.
The wooden part is a center of box elder burl, with bubinga slabs on the sides, with 0.018 aluminum between each strip....then the 45 degree scallops at the ends are ivory acrylic with aluminum sandwiched between the wood and the acrylic. (very much like the recent pens posted by wiset1)
Does anyone have any special method they use, or trick to help avoid a blow-out?
I spent quite a bit of time on this pair of blanks, all eight end pieces --four at the end of each blank-- are glued on with 5 minute
epoxy, and the acrylic I used (the only one I had on hand resembling ivory) is a tad brittle.
I have the Norseman drill bit set,.and they are excellent, but they're so sharp that they sometimes tend to be a little "grabby".
I will be drilling on the lathe.
Is it advisable to drill a small --say, 1/8" or 5/32" -- hole first, and then go to the larger bit?
Also, should I begin at the wooden end and drill toward the scallops, or go thru the scalloped end first?
If anyone has any advice or experience on this they could offer, I would be most appreciative.
Thanks.
Thanks.
