bluesky
I have been having a problem drilling the larger holes in blanks. When using a drill press the end of the hole at the top (first drill entry) seems to end up larger than the hole at the bottom of the blank. The drill bit seems to ream a larger hole because it is in this portion of the blank longer. Consequently, when I glue in a tube one end fits fairly well while the other is very loose and I ususally have to fill in the gap with CA glue. Any suggestions?
David
David
