Ron McKinley
A friend gave me a dozen slimline kits and I don't like the thin center band. So, I drilled a 7mm hole in a dozen or so wood blanks and rough-turned them. Today I tried one with the kits and after I got it assembled the center band is very loose. So, I measured the inside diameter of the kit's center band and found it is only 6.33mm. Is there anyway to make this work? Thanks.......Ron
