hazmat74
I'm probably going to turn a couple of sets of these this weekend. My question is, when drilling them for use on a mandrel, what size drill should I use? I'm assuming a 7mm will be a tad too large.
Why drill them for a mandrel? Put a 60* cone in each end with a hole starter bit and lose the mandrel. If you insist on using one...get out your calipers, measure the shaft diameter and go to the conversion guide in the library to find the drill size.
Matt - what kits are you making them for?
Just slimlines at the moment. That's all I have. I probably don't really need them, but I feel like playing with my metal lathe while I await a shipment from PSI.
