Woodcraft has an 8-collet set, but it is the type that works with a morse taper rather than being threaded directly onto the spindle.
I have the Beall collet set which works perfectly. BUT........
On my cast iron midi-lathe, I also bought a 1/2" keyless chuck with the morse taper. It sometimes loosens up when working on a piece without tail end support. Just spins out. The chuck and workpiece. Not good.
So I had to improvise a 1/4-20 threaded rod draw bar that screws through the lathe, and into the MT chuck, and holds the chuck in place.
And while I'm thinking about I had to do a bit of fine-tuning on the chuck's morse taper shaft. After getting a tight fit in the lathe, the chuck still had a small bit of wobble.
I marked up the tapered shaft with black marker pen and re-inserted the chuck into the lathe. And wiggled it around to see what was causing the not perfect fit.
The problem was not the chuck taper but rather a very slight imperfection in the internal taper of the lathe.
I looked at the chuck arbor, saw that it was just a small, 1/16" or so scratch on the shaft. So I did a bit of easy filing around the scratch, on the chuck taper, and that was it.
That little bit of fine tuning I think is easy to do if you have a similar problem.
Anyway, use a draw bar for all your tapered collets and the Beall system is a truly precision piece of equipment.
Happy turning......
