How about Purple Heart. If you apply some heat after you have finished sanding, you can get a deep purple colour. I do this by using a cloth and applying pressure as if I was polishing. Make sure you glue the tubes in using epoxy because CA will react to the heat and fail. I made a slimline for a friend 2 years ago and the purple colour is still rich.
