KB8JXO
I have been turning some PSI 24K Slimline Click Pro pens and been having problems with the plastic click mechanism not working once assembled. The top and bottom are pressed together into the center and ink is loaded through the screw on tip. I need to separate to two ends to be able to remove and replace the mechanism. Any suggestions?
