Mr Fixit
I've pretty much decided to go with PSI kits for fountain pens, although I could be persuaded otherwise.
I'd like to stick with folks here who are resellers. I've been turning for a while, and only found this place recently. However, I've learned quite a bit in the short time I've been here, so I'd like to throw a little support back to those who have made this place helpful.
I'm interested in fountain pens, in plating other than gold (sterling, chrome, 'gun metal'). Sizes to mimic early Parkers, as well as newer and larger styles. I'm particularly interested in the PSI "Starter packages" where you get the roller ball kit(s) along with the bushings, and drill bits. I'd like to make both roller ball and fountain pens in the same style.
Maybe the most important thing is I want to make sure I have good nibs. So, I'm very interested in kits that will accept the steel replacement nibs from Heritance as a direct replacement.
Where can I find what I need?
Thanks in advance
Mr Fixit
Thanks in advance
Mr Fixit
