PMisiaszek
Recently, I've turned a series of PSI Gatsby pens, their version of the Sierra. I am finding that when the pen is assembled, the tip of the refill does not fully retract into the pen. The transmission advances and retracts the way is should, but the refill tip is visible almost flush with the pen tip assemby and when fully retracted, I can write with the pen. The only variable in the design of the kit is the length of the tube, and I am very careful not to cut down the brass tube in the trimming process. Have others making this pen had the same problem? Is there a fix?
