Hi, I'm looking for kits that have a PDA stylus option. I've just turned several of the PSI 2-way kits and they seem pretty nice. I was hoping for another option, so I tried the Combo kit. The 2 refills are switched by rotating the barell in opposite directions - 1 way pops out the pencil, turning the other way pops out the stylus. The problem I'm finding is that the cartridge is screwed in to the lower brass tube via threads. So when you turn the upper barrel against, the threads, you're fine, but 9 times out of 10, when you try to turn the other way, the mechanism wants to unscrew, rather than switch to the other refill.
Has anyone else experienced this? Any remedy? My first mechanism broke after using it for 5 minutes. Now this second one I can't get the second refill out all the time without the whole pen unscrewing. Is there a chance this is just a bum product and I should just return the unused ones for a refund and forget about it? At $5.50 a pop, plus a nice blank, having these not work out is quite frustrating.
Thanks for any help you may provide.
Aaron
Aaron
