jedgerton
Due to a mistake in the assembly instructions, I damaged two of the PSI cartridge pen kits today. I purchased them from Woodturningz and they informed me of the error with the instructions.
Woodturningz is awaiting a correction from PSI and until then, I would recommend holding off on assembly of this kit. The issue is that in the second step of the existing instructions, you are supposed to press in the nib with its coupler. It takes so much force to accomplish this, the coupling tube in the center coupler is driven out of the plated portion and into the lower tube. I know of no way to reverse this damage.
I know Woodturningz will make this right but in the meantime, if you have this kit, hold off on assembly until the corrected instructions are available.
John
John
