PSI 50 cal kit problem
JamesB
South Carolina
Does anyone else have an issue where the twist mechanism works great until the pen is fully pressed together? I've had a few when I slide the mechanism into the white sleeve it works good and turns easily until it's about half an inch or so from being fully pressed in, then it turns very hard. I've disassembled and cleaned the tube, sanded, filed it, tried a different kit but it doesn't help. The problem is in the tube assembly and not the sleeve. Wondering how to fix this.
