angboy
Is anyone else having problems with their sierra kits? It's one of my favorite pens to make but out of the last 5 or 6 I've put together, I've had problems. On one, the clip piece was WAY too loose and I had to glue it in. On two others, I wasn't able to even push them together. I finally figured out that there was way too tight of a fit where the twist mechanism top part goes up into the clip/finial. At first I thought the upper part of the nib assembly, the part that would be under the tube when the pen is assembled, was where the fit was too tight, so I sanded that area some. But even after a lot of sanding, the last part of putting the two pieces together was just too tight. So I finally realized it was at the other tend of the twist mechanism. After sanding that down some, I was able to get the two pens together. Am I the only one having these problems?
