So I started drilling on my lathe a while back, simpler & more accurate than in a drill press, but I'm having a problem :frown: I turn the blank round first, & then drill through. This works great with short barrels. But due to the length of my drill bits, when drilling a long blank (around 4") I have to drill in from each end, & while the holes do meet in the middle they seem to be somehow "off register" so the tube will slide in most of the way but then binds. Any thoughts? Does anyone here use longer drill bits that will go all the way thro a 4"+ blank & where can I get them from in the sizes we tend to use.
Thanks in advance
David
Thanks in advance
David
