Use the stock bushings to turn the pen and get it's shape. Then get rid of them take the stock metal bushings off and use a set of delran (plastic). To sand and finish your pen. You can make your own. You can use plastic cutting board, PVC, corian to make your own bushings. My finishing bushings I make I use delran. I make the ends smaller remember you already turned it to size. Then I do my final sanding and CA finish micro mesh the CA then I use a parting tool and turn/cut the ends the excess CA that gets on the bushings. Then I use my final plastic polish Novus II.
That's the way I do it.
