Rangertrek
UPDATE: PSI is sending a another dirll bit. I believe the bit I received was stamped incorrectly and will send it back for their info. I recently ordered this kit on the special where you get the sleeves and drill bits with the kits. The instructions indicate using a 33/64 bit for the upper barrel. The bit I received is labeled 33/64. When I put a micrometer on it, it indicates 0.474 diameter. A 33/64 should be 0.515?
The supplied brass tube, which measures 0.510", does not fit in the upper barrel. So, I guess I either have a mis-marked bit or the wrong brass tube. :frown:
Anyone else have this problem?
I have sent an email to PSI; but its the weekend, so you know what that means.
Thanks.
Thanks.
