Thanks for all the comments. I have it narrowed dowm to the bit. I used a new 5/16 pilot point bit in place of the 8mm bit and the bore was perfect. The brad point metric bits I have just don't seem to hold up very well.
Herb
OK, then I'm going to change my guess to "THE BIT".
There. That's my guess and I'm sticking with it.
De Walt Extreme 2 bits are the only ones I use, made in the USA, sold by one or two trusted sellers on this site.
For Slimlines these bits last and last do not track , do not break out on exit with care.
Have success. Peter.
Herb; Most people will advise you to stay away from brad point bits. They work well when drilling across the grain, and help prevent split out when exiting the blank. But I cut blanks in half and drill without breaking thru the opposite end. I then cut off the un-drilled end to exactly the correct length.
Brad points can't be sharpened easily. A Drill Dr. is a good investment as someone else pointed out. But the Drill Dr. can't sharpen brad point bits.
Hope this helps..
