Problem with acrylic blanks - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 03-06-2018, 07:18 PM   #1 (permalink)
Firebucket53's Avatar
Photos: 5
Default Problem with acrylic blanks
I am starting to get into turning acrylic pens. The problem I'm having is pitting. part of the pin blank when I'm finished sanding and buffing there are little pit marks on part of the pin tube. Any suggestions?
__________________
Of all the things I ever lost I miss my mind the most.
Firebucket53 is offline   Reply With Quote Top
Old 03-06-2018, 07:33 PM   #2 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Several possibilities. Any chance for a photo?
__________________
New Contest for 2019 BASH!
Take a look at the rules for what is considered the fairest, best balanced competition for all members:http://www.penturners.org/forum/f18/...-rules-157766/
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 03-06-2018, 07:34 PM   #3 (permalink)
Photos: 0
Default
Sounds like maybe the blank is chipping off small hunks due to a dull tool or aggressive cut. Then during sanding these small chips don't get fully removed.
If you have a picture of this pitting it might help to identify the issue.
Sent from my SM-S975L using Tapatalk
Wagner11 is offline   Reply With Quote Top
Advertisement
Old 03-06-2018, 07:56 PM   #4 (permalink)
Photos: 5
Default Pen blank pic
Here's a picture I hope you can see what I'm talking about.
__________________
Old 03-06-2018, 08:28 PM   #5 (permalink)
MRDucks2's Avatar
Photos: 0
Default
I don’t have a ton of experience by have made plenty of mistakes. If it were my pen it would be what Doug pointed out, chipping of the blank. Guessing that because pits are irregular shape (not casting bubbles) and kind of in a band around the pen.
I tend to get these if I change angle slightly while turning either as I shape the blank or move my hands. Things that help me is to “ride the bevel” of my Skew more as I get close to the final shape and move my body instead of my hands/arms as I move across the blank.
If you are using carbide (which I have less experience at) try more of a cutting angle and not a scraping angle. Some resin does not like carbide as well so lighter, angles cuts.
__________________
Be kind &
Old 03-06-2018, 09:20 PM   #6 (permalink)
WriteON's Avatar
Photos: 0
Default
You'll get past that. I think it's a matter of touch. Use sharp quality tools. Slow and light pressure as you get to the end stage to turning the blank.
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool professional pool cue repair lathe
WriteON is offline   Reply With Quote Top
Old 03-06-2018, 09:29 PM   #7 (permalink)
magpens's Avatar
Photos: 75
Default
Hard to say.
I do know that rhino horn and other horns will pit like that.
Take VERY light cuts.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 03-06-2018, 09:32 PM   #8 (permalink)
More4dan's Avatar
Photos: 5
Default
Also try to keep the cutting edge at or above the centerline of blank. This happens more with inlace acrylister vs AA. You can clean the blank well and fill the pit with a drop of medium to thick CA and let it dry. Skim with A sharp tool and re-sand and polish.
Danny
More4dan is offline   Reply With Quote Top
Old 03-06-2018, 09:36 PM   #9 (permalink)
TonyL's Avatar
Photos: 6
Default
What he said ^
Ed of Exotics has an excellent video on turning acrylics on YouTube
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 03-06-2018, 09:56 PM   #10 (permalink)
Photos: 0
Default
In my very limited experience, all of the above advice is spot on. The type of acrylic and tool used may be helpful for more precise advice. As many have said, when I get those pits it is typically too aggressive of a cut...I'm not very patient and want to see the finished pen too quickly!
Dr_N is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
acrylic , pitting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
