brownsfn2
I have had a frustrating last two nights. I ordered two of the Presimo kits from PSI and the coupler that is on the end of the pen that allows the cap to post seems unsquare. Is it me or does is curve ever so slightly where the shoulder of the coupler meets the shaft (part inserted into the brass tube). It seems like it will not sit flush against the blank no matter how square I have it. I have tried several times.
I called PSI to get a return authorization today and will probably return them but I am wondering if any of you have experienced the same thing? Does it seem like the coupler will not seat right against the blank? Can you see a gap after assembled?
Thanks for your help!
