powdercoating and a propane camp oven
foamcapt40
Delaware, Ohio
I know folks here have done powdercoating pen tubes in a toaster oven but I have a propane camp oven that we don't use and I was wondering about using it for baking the powder coat on. Thoughts? I know I would have to get an accurate thermometer and it may be had to get set.... but I already have it and Thought I would use what I have.
seamus7227
Wichita Falls, TX
I would think as long as you can direct the heat away from direct contact with the tubes you would be ok. When i powder coat my tubes, i use a cheap little $20 toaster oven from walmart. It might be cheaper and less heartache to just buy that rather than build a contraption for what you have
seamus7227
Wichita Falls, TX
Hers a pic of my both that I built,not sure why the picture is sideways, SMH
seamus7227
Wichita Falls, TX
Here is what's in door #2, not much but it's where the spraying of paint happens!!
The very bottom compartment houses the air compressor, above that the paint bottles, then the power supplies and extra storage, then the spray booth and of course above that is the toaster oven. Conveniently located on the right side are three powder coating guns, one of which is a dual voltage gun for multi-layer coatings.
