Believe it or not...too much water can cause too much foaming and resulting to a weaker bond.
I use Gorilla glue (GG) almost exclusivelt but about to experiment on 2 part epoxy now. Anyway, I never had any problems with GG. Here is how I do it. Note, I always do this in batches of atleast 10 (and up to 30 a time)
1. I spread at least a couple sheets of newspaper on top on the table (or any working surface you'll use)
2. Sand the tubes with a coarse sandpaper (the coarser the better)
3. Put on gloves (medical exam gloves work great)
4. Squeeze a glob of glue in both ends of the blank. Note no water here...not even a breath in hole.
5. Spread the glue with a bamboo (BBQ) skewer. (I am still using my first skewer now.)
6. Put the tube in just by the tip.
7. Squeeze some GG along the entire length of the tube. A bit more at the part being inserted.
8. Start inserting the tube rotating the tube as I go in...making sure that there is enough glob of glue covering the area where the tube and blank meet (blank hole opening).
9. Lay the blanks on the newspaper...spaced about 1/4" so they won't accidentally stick to each other (I never had any tube migrate on me yet but you can use rubber band if you want to make sure).
10. Reapeat until all done.
11. Wake up next morning and collect them all...clean up with a knife and I am done! Ready to move on to the drill press with the barrel trimmer
EDIT IN NOTES:
1. The bubbles/blanks may stick to the newspaper but I don't mind.
2. San Antonio is humid...maybe that is why I don't have any problem even without adding water.
3. I did some without sanding the tubes and none of those failed either...I sand for good measure.
Hope this helps.
