jhs494
When drilling a pen blank do you use a brad point bit or a standard drill point?
I am wondering if a brad point drill bit is following the grain or is drilling off caused from some other reason.
Would a standard 118 degree drill point or even a 135 degree split point drill bit help?
I am just thinking really drilling in a vise designed for drilling blanks or drilling in a lathe chuck you should achieve the same results. Only one way the drill bit spins and the other way the blank spins. Any thoughts on this?[?]
